The pedalboard thread...
RoadHigh
Re: The pedalboard thread...
Post by RoadHigh » Thu Jun 25, 2009 1:51 pm
Just got the ODR1 on the board, the RMC2 needs a little modification before itøs getting on the board:
bbrunskill
Post by bbrunskill » Mon Sep 07, 2009 9:33 pm
Here's mine. Only one VL product right now, but I'm thinking of putting a microvibe on top on the PP2+.
I've had much bigger and more involved rigs, but this one sounds great and I can access everything very easily.
Ben
bbrunskill
Post by bbrunskill » Tue Sep 08, 2009 3:04 pm
Trueman wrote:
Here's my Christmas 08 board
Why so many power supplies John?
sasquatch
Post by sasquatch » Fri Sep 11, 2009 6:53 pm
hi james, what is the vdl pedal that says stone on it in the corner?
Trueman
Post by Trueman » Sun Sep 13, 2009 12:04 pm
1 x AC for the Pedal Switcherd
1 x DC for the effects
Connoisseur of good tone.
http://www.guitarpedals.co.nz
Post by JohnClark » Mon Sep 14, 2009 10:35 am
sasquatch wrote:hi james, what is the vdl pedal that says stone on it in the corner?
I'll get this one for James... and sharp eye there, sasquatch! ;)
That is a Voodoo Lab Bosstone which is long out of production, however it is what the Super Fuzz was born from. This was a copy of the Jordan Electronics Bosstone and had only Volume and Attack controls. We added the Tone and Resonance controls to it and named it Super Fuzz. A Super Fuzz with the Tone in the middle and the Resonance all the way down is a Bosstone.
kairos05
Post by kairos05 » Thu Sep 16, 2010 10:17 am
bbrunskill wrote:Here's mine. Only one VL product right now, but I'm thinking of putting a microvibe on top on the PP2+.
Ben
Hello! what did you do to power your TimeFactor with the PedalPower??
Thank you!
Post by JohnClark » Thu Sep 16, 2010 10:29 am
kairos05 wrote:Hello! what did you do to power your TimeFactor with the PedalPower??
Thank you!
The TimeFactor is powered from outputs 5 and 6 using a Current Doubling cable.
kairos05
Post by kairos05 » Thu Sep 16, 2010 12:57 pm
Thank you!
Is the current doubling cable the same thats used to power a 18v pedal using 2 9v outputs on the PedalPower?
Thank you so much for the help John!!
Post by JohnClark » Thu Sep 16, 2010 3:58 pm
kairos05 wrote:
Thank you!
No, these are not the same cable.
The Current Doubler cable connects two outputs in parallel to add the available current of the two outputs together.
The Voltage Doubler cable connects two outputs in series to add the voltage of the two outputs together.
