It is currently Sun Jun 17, 2018 5:17 pm
 Post subject: Nice Rack Canada | Galen Weston | Fly Rig
PostPosted: Wed Jan 13, 2016 5:32 pm
Here's a tasty set of tone tools designed, fabricated & programmed by Nice Rack Canada for Toronto based jazz guitarist, Galen Weston.
The system is MIDI Controlled & Audio Switched by the standard setting RJM Music MasterMind PBC.
The signal flow is Guitar --> Input Buffer with 2 outputs; (A) --> Rupert Neve DI for Re-amping track & (B) --> Xotic Wah --> Volume Pedal with 10kΩ Output --> PBC In 1 --> Loop 1 Xotic SP Comp --> Loop 2 Ibanez TS9 MIni #1 --> Loop 3 Ibanez TS9 MIni #2 --> Loop 4 ZVex Fuzz Factory --> Loop 5 Electro Harmonix Big Muff Nano --> Loop 6 Xotic EP Boost & Nice Rack Canada Volume Cut --> Loop 7 Eventide H9#1 (Diatonics & Modulations) --> Loop 8 Strymon TimeLine #1 --> Loop 9 Strymon TimeLine #2 -- Loop 10 H9#2 (Reverb) --> PBC Output A --> Amplifier. PBC Output B --> Baggs Para DI
Powered by Voodoo Lab Pedal Power Digital
Nice Rack Canada
 Post subject: Re: Nice Rack Canada | Galen Weston | Fly Rig
PostPosted: Wed Jan 13, 2016 6:11 pm
Did you mod the FV-30 with led'S??? amd why??
Pascal
Marshall JVM 210H 100w
1960a cab with G12T75 and Vintage 30's
Fractal Audio AX8
Guitars:
IBANEZ JEM PMC
IBANEZ JEMjr Desert Yellow
EVH Wolfgang Vintage white
PostPosted: Thu Jan 14, 2016 8:19 am
Pascal
Yes, we modded the FV-30 with an Output Buffer circuit with an Input Impedance of 1mΩ to load the volume pot as nicely as possible, the Buffer's output impedance is 10kΩ, making it an ideal impedance for input to the Overdrives & Fuzzes.
