Electric shock from voodoo mondo
wario
Post by wario » Fri May 11, 2018 4:22 am
I am stay in Thailand.
I bough voodoo mondo 2 weeks ago.
This mondo shock me when I am toughting the scruw on mondo.
I use 2 pin power cord from the mondo package.
I check it by screwdriver electrical tester , It have electric from scruw.
Is It normally ?
How can I do?
Re: Electric shock from voodoo mondo
Post by JohnClark » Fri May 11, 2018 10:14 am
That points to a faulty, or missing, AC Mains Ground connection. Does the wall outlet you are using have the Ground pins that connect at the sides of the plug like this Type F outlet or does it only engage the two prongs like this Type C outlet?
Also, in your pictures, where are you connecting the other end of your tester?
wario
Post by wario » Fri May 11, 2018 9:34 pm
This picture show my wall outtet and mondo cord
Does the mondo alway need the ground connection ? Why?
Is this mondo connected ground loop on its metal box?
Is I need to change power cord?
Post by JohnClark » Wed May 16, 2018 5:50 pm
Ah-Ha! You will need to change the power cord to one that has a ground pin on it.
