Daisy chaining power from PPP2 to three pedal switcher pedals and one commander
FFA
Post by FFA » Tue Mar 26, 2019 12:58 pm
Does anyone know what the current requirements of the voodoo lab floor pedal switcher is? I have three plus a commander and limited power outputs.
Re: Daisy chaining power from PPP2 to three pedal switcher pedals and one commander
Post by Rez » Tue Mar 26, 2019 1:42 pm
Pedal Switcher(s) cannot be daisy-chained, they need to be powered from isolated outputs or there will be significant hum/buzz noise.
That said, 3 Pedal Switchers and a Commander could be powered with Pedal Power 2 Plus using four outputs (#5, 6 and two of 1-4) and a Current Doubler Adapter, part# PPAP.
But... before explaining further, does this still seem like a desirable possibility for your situation?
FFA
Post by FFA » Tue Mar 26, 2019 4:50 pm
Thanks for the help but why 4 outputs when the commander can be phantom powered by one of the switches?
Post by Rez » Wed Mar 27, 2019 9:44 am
Because, one of the three Pedal Switchers will need to be powered using two outputs, setup:
To power the 3rd Pedal Switcher use a Current Doubler Adapter, part# PPAP in any two of outputs 1-4, DIP switches set away from normal (12VDC) and with the supplied red/black ended cable (it's 2.1mm/2.5mm reverse polarity and the red end fits the Pedal Switcher).
FFA
Post by FFA » Sat Mar 30, 2019 8:54 pm
Thanks REZ! Just to clarify outputs 5 and 6 dip switches remain in the off position while 1 and 2 ( assuming I use these two with doubler) are on?
Post by Rez » Mon Apr 01, 2019 11:24 am
Ah... sorry for not specifying previously.
The DIP switches for outputs 5 and 6 (powering 2 x Pedal Switcher and 1 x Commander) would also be set AWAY from the normal 9V setting.
FFA
Post by FFA » Mon Apr 01, 2019 8:49 pm
Post by Rez » Tue Apr 02, 2019 10:54 am
