It is currently Sun Jul 15, 2018 3:53 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Database of Effects Pedals that Pedal Power operates:
PostPosted: Sat May 30, 2009 9:37 pm
List the Effects you power off the Pedal Power and how:
1) TC Electronics Nova Delay
Power Cable: http://www.t-rex-engineering.com/Defaul ... ID=PROD172
Outputs: 5+6
DIP Switch Non-Normal
2) Boss TU-2
Power Cable: PPBAR-R from http://www.voodoolab.com/cables.htm
Outputs: 1-8
DIP Switch Normal
3) Deluxe Memory Man
Power Cable: 18v/24v 5.5mm x 2.5mm - Reverse Polarity (straight) from http://www.voodoolab.com/cables.htm
Outputs: 1+2
DIP Switch Normal
Connoisseur of good tone.
http://www.guitarpedals.co.nz
 Post subject: Re: Database of Effects Pedals that Pedal Power operates:
PostPosted: Sat May 30, 2009 11:29 pm
4) Line 6 DL4/MM4/FM4
Power Cable: 5.5mm x 2.5mm “Red” Barrel from http://www.voodoolab.com/cables.htm
Outputs: 5 or 6
PostPosted: Wed Jun 03, 2009 1:14 am
Bump. Comon guys post your pedals here. I believe this could be a very useful database.
PostPosted: Fri Jun 12, 2009 12:31 pm
Ok 8-) In my list I kinda have to include other things that I power off of the PP2+ besides pedals.
Boss Dimension C DC-2:
Regular polarity black cable
output 1-8
Switch: Normal
MXR 74 HW Vintage Phase 90
No power jack on these:
Battery Tab power cable
output 1-8
Switch: Normal
80's Ibanez/Maxon CS-9:
Can power through the jack, but I use the bat. tab
outputs 1-8
Switch: Normal
Vintage MXR AC corded Flanger:
Courtesy Outlet(get a nasty ground loop here though)
Others:
Axess Electronics GRX4 router/switcher:
output 1-8
Switch Normal
Sound Sculpture ABCadabra midi loop/ a/b/y:
Reverse Polarity white end cable
output 1-8
Switch Normal.
Testing and will update:
Midiman thru 3x8
line 6 red tip cable
output 5/6
PostPosted: Fri Jun 12, 2009 4:37 pm
Nice stuff! Thanks for contributing
PostPosted: Sat Jun 13, 2009 7:58 am
Hello,
As a manufacturer of power supplies I have a database with more than 600 pedals I have measured with information about the stated nominal voltage, stated curent draw according to the manual or specifications, the actual measured current draw both in stand-by and activated mode and the type of plug needed to power the pedal. Please e-mail me your list of pedals and I'll return the information you need.
Poul Ciok
PostPosted: Sat Jun 13, 2009 9:38 am
Poul... you beat me to it! I think it is fantastic that you guys are willing to share around info like this as you are 'rival companies'...
Yes, the 'Cioks Current Comsumption Table' is a very useful document which I have consulted many times... here is the actual link:
http://cioks.com/media/current_consumption_table.pdf
PostPosted: Sat Jun 13, 2009 3:07 pm
The online published version of CCT is quite old. I stopped updating it online in 2004 and now I'm only updating the one on my laptop. Healthy competition is good and for you customers out there it's the best natural mechanism, which with time gets you better and better products. We at CIOKS only do power supplies and in few days you'll see a forum treating the subject of powering effect pedals on our web site as well.
Poul Ciok
PostPosted: Sun Jun 14, 2009 10:31 am
Site Admin
poulciok wrote:
The online published version of CCT is quite old. I stopped updating it online in 2004 and now I'm only updating the one on my laptop...
Poul Ciok
So you're not interested in 'sharing' information at all. It looks like your interest is getting a little free advertisement on the Voodoo Lab website!
Josh Fiden
Founder / CEO
PostPosted: Tue Jun 16, 2009 11:10 am
None of the pedals I own are on that list. :?
Users browsing this forum: No registered users and 8 guests
