It is currently Fri Jan 19, 2018 1:56 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Mon Aug 08, 2016 10:39 am
Loride wrote:
There is no cable that does both... There is one cable for Doubling the Voltage and one cable for Doubling the Current.
The Current Doubler Adapter (the one with the Green end) will only combine the Current of the two Outputs used. And both Outputs would need to be set to the same Voltage.
However, in your case this still won't help much since the Mobius requires more current than is available. For the Mobius you will need to use the included power adapter connected to the Courtesy Outlet on your older model Pedal Power 2.
PostPosted: Mon Aug 29, 2016 8:00 am
Hi there!
Is it possible to use this cable to combine the 400mA outlet and a 100mA outlet of the Iso 5 (to get 500 mA), then use one of your Y splitter cables into this cable to get 2 outputs of 250mA each?
Chris
PostPosted: Mon Aug 29, 2016 10:09 am
Christop wrote:
Hi there!
Chris
Sure, you can stack these two adapter cables. You would have total of 500mA available between the two jacks on the Output Splitter.
What are the two pedals you are trying to power?
PostPosted: Mon Aug 29, 2016 12:26 pm
Great news, thanks man! I'm wanting to power a strymon el capistan and a digitech whammy ricochet (approx 235 mA), so hopefully this will fit the bill.
PostPosted: Sun Sep 04, 2016 1:54 am
Cool, got this set up and working - thanks again man!
PostPosted: Wed Dec 21, 2016 12:51 pm
The new Digitech Trio+ pedal uses 9vdc 800mA external adapter. I've got a 4x4 power unit, can I use a current doubler cable on the 400mA ports to adequately power the Trio+?
If not, do you have any other recommendations from among the Voodoo Labs power supply product line?
PostPosted: Wed Dec 21, 2016 4:46 pm
The actual max current draw of the Trio+ is about 450mA. You could use a 9V/400mA output together with any other 9V output on a 4x4 with the Current Doubler Adapter (the one with the Green end).
I would suggest using the Current Doubler for total reliability, however you may be able to get away with powering it from a single 9V/400mA outlet if you are not loading the other outputs all to their maximum.
PostPosted: Wed Jan 10, 2018 4:53 pm
Howdy! I'm trying to power my Korg Kaoss Pad KP3 which wants 700mA 12v center positive with a pin in the barrel. The strange barrel is no problem, I made an adapter which reverses polarity and adapts from a normal barrel to a Kaoss barrel. I also have another barrel adapter which I have successfully used with a different 12v 2A adapter
However, my current doubler doesn't seem to work. I'm pulling from two 12v 375mA outputs (Strymon Zuma) into the Voodoo current doubler, through the barrel adapter & polarity reverser, which should be just more than enough for the 700mA KP3. The thing doesn't light up, even for a brief second.
Am I doing something wrong?
PostPosted: Thu Jan 11, 2018 12:56 pm
Are you able to test the polarity/barrel adapter cable you've made using 12V 2A power supply?
What is the barrel connector you used on the cable you've made? Judging by pictures of the KP3+ (is yours the "KP3+" or is it "KP3") it looks like a fairly normal Barrel connector in either 2.1mm x 5.5mm or 2.5mm x 5.5mm.
Are you sure you have the Voodoo Lab Current Doubler Adapter (the one with the Green end), and not the Voltage Doubler (all ends black)?
PostPosted: Sat Jan 13, 2018 6:11 am
Hi all !
I bought a used PP2+ recently, but it doesn't include the actual cables to connect to the pedals. I've got an MXR Power Brick, though, with plenty of cables. Will I be able to use these same power cables without any issues or does the PP2+ use proprietary connectors?
Cheers
My website
