Current Doubler Adapter cable (p/n PPAP)
sweetmamalandry
Re: Current Doubler Adapter cable (p/n PPAP)
Post by sweetmamalandry » Sun Jun 16, 2013 11:46 am
I have a Carl Martin Octa-Switch that needs 9V regulated w/ 400mA...can I use the current doubler on outputs 5 & 6 of my Pedal Power 2 Plus to power it? Should the dip switches be in the NORMAL position?
Currently, I am powering it with a Visual Sounds 1 Spot...which is a complete hassle to thread up under my Pedaltrain every time I play and run to an extension cord.
Thanks. :D
sweetmamalandry
Post by sweetmamalandry » Thu Jun 20, 2013 9:48 pm
Hello, is there anybody here?
Post by JohnClark » Tue Jul 09, 2013 10:18 am
sweetmamalandry wrote:I have a Carl Martin Octa-Switch that needs 9V regulated w/ 400mA...can I use the current doubler on outputs 5 & 6 of my Pedal Power 2 Plus to power it? Should the dip switches be in the NORMAL position?
Thanks. :D
Sorry, didn't see you hiding up here.
The Octa-Switch and the Octa-Switch II, actually draw less than 200mA and can be powered directly from output 5 or 6 with the corresponding DIP switch set to Normal using one of the regular barrel cables.
sweetmamalandry
Post by sweetmamalandry » Fri Jul 12, 2013 1:52 am
Thanks for the reply.
I had already ordered the current doubler adapter cable...and tried it and it was very NOISY. I had already found your reply on someone else's post about powering the Octa-Switch...and tried output #5 in the "normal" position on my Pedal Power 2 and YAY, it powered up just fine and quietly!
So, turns out I didn't need this cable after all! ;Debbie
Teddy59
Re: Current Doubler Adapter cable for centre +ve pedal
Post by Teddy59 » Sat Jul 19, 2014 1:09 am
Hi
I have an Effectrode Helios fuzz pedal that requires 12VDC @ 350mA (centre +ve) and a PP2+.
Can I use the PP2+ 5 and 6 output in the away from Normal position in a reverse polarity configuration?
Many thanks,
Teddy
Post by JohnClark » Mon Jul 21, 2014 2:58 pm
Teddy59 wrote:Hi
Many thanks,
Teddy
Until I can get my one on my bench for testing, I wouldn't suggest using anything but the supplied adapter for the Helios. You can plug the supplied adapter into the Courtesy Outlet on the back of the Pedal Power 2+.
Teddy59
Post by Teddy59 » Mon Jul 21, 2014 3:13 pm
Hi John I also came to that conclusion too. Better to be safe and sure before trashing my new investment!
All the best Teddy
kdm1218
Post by kdm1218 » Mon Jul 28, 2014 12:08 pm
A question about the eventide timefactor- can it power off the courtesy outlet on the PP2+ or has to run with the set up shown in the other thread?
Post by JohnClark » Mon Jul 28, 2014 12:11 pm
kdm1218 wrote:A question about the eventide timefactor- can it power off the courtesy outlet on the PP2+ or has to run with the set up shown in the other thread?
Any pedal that comes with an adapter can be powered by connecting the supplied adapter to the Courtesy Outlet.
synyster_slash
Post by synyster_slash » Mon Aug 25, 2014 5:31 am
What would happen when using the 'current doubler' cable to combine one of the 250ma outputs with one of the 100ma ouputs?
