NEW USER...Questions- please help!...
zen_radio
Post by zen_radio » Sun Jul 26, 2009 3:14 pm
I recently purchased PP2 and have a question. Need power cords for the
following, if available (if the cord with the unit are useable for any
of these, let me know which cord for what effects(?):
Trace Elliot - trace dual acoustic compressor [INPUT- 120VAC, 60HZ,
5VA OUTPUT- 18v, 100ma] a barrel type that looks like any other(?)
Maxon Compressor [DC in 9v/10v] (-using a '1-spot' model NW1-US at
this time to power it)
Visual Sound H2O chorus/delay [needs regulated 9V DC negative polarity
adaptor] (-also using a '1-spot' NW1-US adaptor for this*)
Dunlop Crybaby (model GCB-95) a 'jack' type adaptor, not barrel. I've
always used a 9v battery, but might power it if it's possible...
Any help would be greatly appreciated!
Thanks, zen_radio
Re: NEW USER...Questions- please help!...
Post by JohnClark » Mon Jul 27, 2009 4:42 pm
All of these should be powered from any of the outputs with the DIP switch set to Normal*
For the Trace Elliot Compressor you would need the 18v/24v 5.5mm x 2.1mm cable. This can be purchased directly from us or ordered through any Voodoo Lab dealer.
Both the Maxon Compressor (CP-101 or CP-9) and the Visual Sound H2o pedals would need a standard barrel cable that came with your Pedal Power 2+. (*If the Compressor is the CP-9 Pro+ then you will need to run it from output 5 or 6 with the DIP switch in the Normal position)
The Dunlop GCB-95 will need the 1/8" Mini plug that came with your Pedal Power 2+.
zen_radio
Post by zen_radio » Mon Jul 27, 2009 6:05 pm
Thanks! I'll be ordering the extra cable, soon...plus a few other 'extras'. I sincerely appreciate your help.
zen_radio :D
