Voodoo Lab
http://voodoolab.com/forum/
Pedal Power AC auxiliary to power amp
http://voodoolab.com/forum/viewtopic.php?f=7&t=5367
Author:  Binnibo [ Sun Apr 06, 2014 12:40 am ]
Post subject:  Pedal Power AC auxiliary to power amp
Hi. It says in the manual for pedal power 2 plus:
"Do NOT plug in your
amp here!"
In the ac aux that is.
But it also says 200 watts max.
So my question is; can i run an Excelsior 13 watt guitar amp ( it says 75 watts on back of the transformer, 230).
Author:  JohnClark [ Mon Apr 07, 2014 10:33 am ]
Post subject:  Re: Pedal Power AC auxiliary to power amp
75 is less than 200... Plug that bad boy in and get to rocking!
Author:  Spinach [ Sun Nov 26, 2017 5:51 pm ]
Just wondering if the AC Auxiliary port is safe to power the new Vox MV50 AC Amp Head.
http://www.voxamps.com/uploads/SupportP ... EFGSJ1.pdf
I checked the online manual of the amp head, it says the following
> Power Supply: AC Adapter DC19V (-) to (+)
> Current Consumption: 3.43A
So based on the conversion Watt = Voltage x Amp, this would mean 19V * 3.43A = 65.17W.
So, will this be safe since the AC Auxiliary outputs Max 200Watt.
EDIT: Also, the AC Auxiliary is currently powering my Strymon OJAI... so my other question would be, is it safe for AC Auxiliary to power the Vox MV50 as well as an OJAI PSU unit.
Spnach
Author:  JohnClark [ Mon Nov 27, 2017 11:44 am ]
Spnach
It should be no problem to power both of these using the Courtesy Outlet.
http://www.phpbb.com/
