Pedal Power 2 Plus and ToneBone PZ Pre
gregpatent
Post by gregpatent » Mon Jan 19, 2015 4:31 pm
Is there are way to use the Pedal Power 2 Plus to power a 15VDC 400mA Tonebone PZ Pre acoustic preamp pedal?
Re: Pedal Power 2 Plus and ToneBone PZ Pre
Post by JohnClark » Wed Jan 28, 2015 6:09 pm
You can use the supplied adapter connected to the Courtesy Outlet on the back of the Pedal Power, but none of the front panel outputs will support 15V.
wildmon
Post by wildmon » Sun Aug 14, 2016 1:23 am
You can use a cable with a 2.1mm right angle and 2.5mm (red) right angle barrel connector and reverse (center positive) polarity designed to power Line 6 DL4/MM4 digital modeling pedals, Eventide Factor, some Electro-Harmonix and Voodoo Lab Pedal Switcher and Control Switcher. You have to run it through the L6 connector on the Voodoo Lab which changes it from regulated 9V to unregulated. I tried it and it worked great and the cable is only $3.50. You can also purchase a stagebug made by Radial for $99 and run two 9V outputs into the stagebug. As long as there is no danger in damaging your PZ-Pre I see no reason not to use the red chord. I can't find any info online that says it's safe though.
Post by JohnClark » Mon Aug 15, 2016 12:57 pm
wildmon wrote:You can use a cable with a 2.1mm right angle and 2.5mm (red) right angle barrel connector and reverse (center positive) polarity designed to power Line 6 DL4/MM4 digital modeling pedals, Eventide Factor, some Electro-Harmonix and Voodoo Lab Pedal Switcher and Control Switcher. You have to run it through the L6 connector on the Voodoo Lab which changes it from regulated 9V to unregulated. I tried it and it worked great and the cable is only $3.50. You can also purchase a stagebug made by Radial for $99 and run two 9V outputs into the stagebug. As long as there is no danger in damaging your PZ-Pre I see no reason not to use the red chord. I can't find any info online that says it's safe though.
http://www.voodoolab.com/forum/viewtopic.php?f=7&t=7032
