It is currently Thu May 24, 2018 4:11 pm
Post new topic Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
 Post subject: PP 2 Plus and Flashback x4
PostPosted: Fri Feb 27, 2015 1:18 pm
Will the pp2 plus power the TC Electronic Flashback X4?
If so, how?
 Post subject: Re: PP 2 Plus and Flashback x4
PostPosted: Fri Feb 27, 2015 3:33 pm
The Flashback X4 can be powered from output 5 or 6 on a Pedal Power 2+ with the corresponding DIP switch set to Normal using one of the included standard all black barrel cables.
PostPosted: Fri Feb 27, 2015 3:46 pm
Even when the current draw of the flashback is 300mA and the outputs 5-6 have 250mA current output?
PostPosted: Fri Feb 27, 2015 3:57 pm
The actual current draw of the Flashback X4 is around 200mA.
PostPosted: Fri Feb 27, 2015 4:25 pm
I checked on other forums and it is close to 200mA, thank you very much!! :D
PostPosted: Tue May 12, 2015 8:29 pm
More of the same question, can the PP 2 Plus power up a Morley Mark Tremonti Wah?
PostPosted: Wed May 13, 2015 11:59 am
You can power any model of the Tremonti wah from any output on a Pedal Power 2+ with the corresponding DIP switch set to Normal.
PostPosted: Wed May 13, 2015 6:09 pm
Ok!! Thank you :D
PostPosted: Mon Mar 13, 2017 10:04 am
If the DIP switch for the L6 port is set to "on" would it break the Flashback x4?
PostPosted: Mon Mar 13, 2017 10:14 am
I wouldn't recommend using it that way... I'm not sure it will actually damage the pedal but it isn't the right setting.
