Rane SM26 power supply
Marlboro05
Post by Marlboro05 » Sun Nov 27, 2016 2:02 pm
Hi there,
Wondering if it is possible to make a cable to supply power to a Rane SM26 with the Pedal Power AC? Is it possible to make it with 2 supplies to the RJ14 plug (telephone 6pin).
Here is a link to the power supply that Rane used to supply.
http://www.rane.com/rap.html
Cheers Brett
And some other stuff.
Re: Rane SM26 power supply
Post by JohnClark » Mon Nov 28, 2016 12:49 pm
I'm not too sure it would work since the original power supply is actually an 18V output with a Center Tap and not necessarily two seperate 9V outputs.
It would certainly take some experimentation at the very least since the phase relationship between the outputs on the Pedal Power AC transformer was never specifically defined... meaning that it is possible that it changed between different production runs.
skippertronic
Post by skippertronic » Sat Mar 18, 2017 8:11 pm
Bump.
For a Rane SM 82 line mixer, it has that RJ plug...could Voodoo Lab make an adapter power cable that could plug into a pedal power? It says 650mA on the back of the Rane.
I think there are many Rane users that would find this type of cable very useful.
