It is currently Tue Jan 16, 2018 12:21 pm
 Post subject: Using 220-240 vac in taiwan
PostPosted: Sat Apr 08, 2017 11:31 pm
Hi all experts here,
I currently owns a voodoo lab PP2 which runs i believe
On 220-240vac *location:singapore*. As I will be having a gig in taiwan this year, will I need a power convertor for iit to work in Taiwan? I checked and the supply there is 110/120 V.
 Post subject: Re: Using 220-240 vac in taiwan
PostPosted: Mon Apr 10, 2017 9:18 am
Yes, you will need a Step Up transformer to operate your 220-240VAC Pedal Power from a 120VAC mains.
PostPosted: Wed Apr 12, 2017 4:25 am
Hey thanks for helping.any type of step up transformer will do?(those plug thingy?)
PostPosted: Wed Apr 12, 2017 10:03 am
A simple plug converter will not work. You need a Step Up Transformer that coverts the voltage.
A fully loaded Pedal Power 2+ will consume less than 20 Watts. Add to that the Wattage of whatever you may have connected to the Courtesy Outlet to find your minimum Wattage need for a Step Up transformer.
PostPosted: Wed Apr 12, 2017 10:26 am
Alright thanks!any brands to recommend??
PostPosted: Mon Apr 17, 2017 11:34 am
You should be able to use just about anything you can find that provides the minimum Wattage necessary. I just don't know what sort of things you will find in Singapore. ;)
