ISO 5
Mauro
ISO 5
Post by Mauro » Sun Apr 30, 2017 4:15 am
Hi, i have a power iso 5 pedal to which I connected a boss, a tc electronic subnup and a pulsar elektro harmononix to 3 9v outputs, i recently bought your y cable to one of the 3 9v outputs by connecting an electo harmonix freeze (So I have 4 9v pedals in the 3 9v outputs) and there is ground wire, you know how to help me?
Re: ISO 5
Post by JohnClark » Mon May 01, 2017 9:31 am
The Electro Harmonix Freeze should be powered from the High Current 9V Output. It will not work to power this pedal from one of the first three 9V Outputs.
You can still use the Output Splitter Adapter, but you will need to either use it with a different pedal, or from the High Current Output for the Freeze.
What else are you powering from your ISO-5?
