Pedal Power AC
1meanplexi
Pedal Power AC
Post by 1meanplexi » Sun Aug 13, 2017 11:00 am
I have my rig built and it is fantastic. I need to know if I can use the Pedal Power AC to power my ISP Decimator Pro Rack G and the GCX switching system? Sick of the wall warts falling out. Thanks in advance for your answers.
Re: Pedal Power AC
Post by JohnClark » Mon Aug 14, 2017 10:13 am
Yes, a Pedal Power AC can power both of these, no problem.
The Decimator ProRackG can be powered from any 9V Output on the Pedal Power AC.
The GCX can also be powered from any 9V Output on the Pedal Power AC, but if it it providing Phantom Power to a Ground Control or Ground Control Pro, it should be powered from one of the higher current 9V outputs to the right.
Alternatively, a little bit of Dual Lock and/or a small right angle bracket can be used to hold a wall wart adapter in place.
1meanplexi
Re: Pedal Power AC
Post by 1meanplexi » Mon Aug 14, 2017 10:27 am
You are the best John. Thank you.
