It is currently Sun Jul 22, 2018 7:36 am
 Post subject: tc vintage delay with pp2+
PostPosted: Sun Aug 27, 2017 8:35 am
hello everybody,
does this delay pedal works with the pp2+???
specs 12V AC min 300mA
http://www.tcelectronic.com/vintage-delay/tech-specs/
thank you very much,
 Post subject: Re: tc vintage delay with pp2+
PostPosted: Mon Aug 28, 2017 12:02 pm
The link you provide says 12VDC...
That said, I believe the Vintage Delay draws much less than the stated 300mA and can actually be powered from a Pedal Power 2+ directly from output 5 or 6 with the corresponding DIP switch set away from Normal.
PostPosted: Mon Aug 28, 2017 9:24 pm
ok thanks,
doe this cable works correctly with ?
https://www.thomann.de/fr/voodoo_lab_cu ... dapter.htm
PostPosted: Tue Aug 29, 2017 9:45 am
The Current Doubler would be unnecessary. You can use one of the standard all black barrel cables included with your Pedal Power 2+ to power this pedal from a single output if you use output 5 or 6 with the corresponding DIP switch set away from Normal.
However, if you were already using these outputs you could actually use the Current Doubler on any two of outputs 1-4 with the corresponding DIP switches set away from Normal.
Are you already using outputs 5 and 6 for something else?
PostPosted: Tue Aug 29, 2017 10:45 am
thanks so much
no not yet.
I try tonight
