JohnClark wrote:
The DIP switches are indeed oriented in the same order as the jacks they are associated with... they are even numbered to match the jacks they are associated with.
In your case, both pedals we know about should be on jacks that are set to Normal. Have you tested these pedals with nothing else connected to see if they then behave correctly?
What are the other pedals you are powering with this Pedal Power 2+?
OK, I figured, but with no labels on the bottom (installed on a pedal train) I thought I would ask. In addition to the nano Small Stone and the El Capistan I have an Iguana Tail 5 Channel looper, Bass Big Muff, Russian Big Muff V7 or 8 with a 9V cable connector, Dirty Little Secret MKII with voltage doubler cable for 18V, Axtron CHR5, a VooDoo Labs Tremolo, Boss OC2 and a PolyTune Mini 2. I believe the tuner, chorus and octave are powered via the Iguana Tail.
I'll disconnect all the pedal except the phaser and the El Cap and report the results. Thanks for your help!
