It is currently Thu Jul 19, 2018 7:27 pm
 Post subject: PP2+: Why only 200W for Courtesy Outlet?
PostPosted: Tue Aug 29, 2017 1:03 am
I am a new PP2+ owner, and want to power my Fender Blues Junior (180W consumption) from the courtesy outlet.
Though I am under the limit of 200W max specified for the courtesy outlet, I am curious what exactly limits the wattage on that outlet to 200, especially as it is wired directly in parallel with the main AC input for the PP2+? Why not 300 or 500 Watts? The outlet looks as solid as the power strip I use for bigger amps, like a Vox AC30.
So: what build aspect of the courtesy outlet limits the wattage? Is it the diameter of the interconnecting wiring? Some other issue? Legal liability?
 Post subject: Re: PP2+: Why only 200W for Courtesy Outlet?
PostPosted: Tue Aug 29, 2017 9:40 am
It's some of all the above ;)
The limit was somewhat made up, somewhat calculated, somewhat determined to cover our rears. :)
It will be perfectly safe powering the amp you describe via the Courtesy Outlet.
