It is currently Thu Apr 26, 2018 2:01 pm
 Post subject: Pedal power 2 and Two Notes Le Bass
PostPosted: Wed Nov 08, 2017 5:02 pm
I have the Pedal Power 2. Will this be able to power the Two Notes Le Bass preamp? It requires 12v 500ma :?:
 Post subject: Re: Pedal power 2 and Two Notes Le Bass
PostPosted: Thu Nov 09, 2017 11:18 am
Do you have the Pedal Power 2, or do you maybe have the Pedal Power 2+?
The Le Bass should be able to be powered from a Pedal Power 2+ using outputs 5 and 6 with their corresponding DIP Switches set away from Normal combined with a Current Doubler Adapter (the one with the Green end).
If you have the Pedal Power 2 (not the + version) then I would suggest plugging the power adapter supplied with the Le Bass to the Courtesy Outlet.
