It is currently Fri Apr 20, 2018 11:35 am
 Post subject: running Electroharmonix 720 looper with a VL2 power supply
PostPosted: Wed Nov 15, 2017 5:20 pm
I just purchased a Voodoo Lab 2 plus. I want to power an Electroharmonix 720 looper. I have looked over the info for both, but I'm a total newbie to all this stuff, and don't feel very sure about which outlet on the power supply to use for the looper. I also have an Electroharmonix Canyon, which I've arleady run off of one of the first three outputs, and thankfully it didn't blow up on me. Can anyone out there help me out?
Thanks! --DRB
 Post subject: Re: running Electroharmonix 720 looper with a VL2 power supp
PostPosted: Thu Nov 16, 2017 12:28 pm
The 720 can be powered from any output with the corresponding DIP Switch set to Normal.
The Canyon needs a little more current so it should actually be powered from Output 5 or 6 with the corresponding DIP Switch set to Normal. No harm will have occurred from using it the way you had it, but it will likely result in unexpected behavior to continue using it that way.
PostPosted: Thu Nov 16, 2017 8:44 pm
Thanks, big help!
Users browsing this forum: No registered users and 11 guests
