Voodoo Lab http://voodoolab.com/forum/ |
OCD with Pedal Power 4x4 http://voodoolab.com/forum/viewtopic.php?f=7&t=8648 |
Page 1 of 1 |
Author: | hamabdullah [ Mon Dec 04, 2017 12:44 am ] |
Post subject: | OCD with Pedal Power 4x4 |
Hi Labgods, need help to place OCD on the 4x4 as I've been getting mix answers reading thru the forum. Where can I place the OCD with the 4x4? Can I put it on the 9v or the 9v high 400ma area? please help |
Author: | JohnClark [ Mon Dec 04, 2017 4:35 pm ] |
Post subject: | Re: OCD with Pedal Power 4x4 |
The OCD will accept 9-18V DC so it can be powered from any output on a Pedal Power 4x4, 9V or 12V. If you wanted to run it specifically at 18V you will need a Voltage Doubler Adapter connected to any two 9V Outputs. For the current rating, a pedal will only draw the amount of current it needs to operate. The OCD somewhere around 10mA so it would be equally fine from either the 100mA or 400mA outputs. I hope that helps! |
Page 1 of 1 | All times are UTC - 8 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
