Pedal power problem
marco polo
Pedal power problem
Post by marco polo » Mon Jun 25, 2018 3:26 pm
Hello, first time user here. Question regarding Pedal Power 2. It powers up (red light on) has 9 volts going to pedals (standard Boss pedals) pedal does not power up? I have read the PDF and understand all.The only thing i think is that the lead with the red tip supplied to connect the daisy chain might be negative tip? Have no idea what is going on if someone can help.
Regards
Marc
Re: Pedal power problem
Post by JohnClark » Mon Jun 25, 2018 3:57 pm
Boss pedals should use only the standard all black barrel cables. Also, in order for a Boss pedal to power up, there has to be a standard guitar cable connected to the Input jack.
What exact pedals are you powering?
