Newbie could use some help/advice
DeanoGuitarist
Post by DeanoGuitarist » Fri Jun 29, 2018 7:12 am
Hi Guys!
Feeling a little overwhelmed here, I wonder if somebody could advise me please?
I am looking to buy a Pedal Power, but dont know what is the correct one for me....
My board has the following......
Behringer FCB1010 (probably still needs standard power from regular plug I accept that)
TC Electronic "Polytune 2"
Digitech "The Drop" pedal
JOYO JF-01 Vintage Overdrive
Veleton "Comprince" Vintage Compressor
Rocktron "Banshee 2" Talk box
Line 6 Guitar Wireless "G70 Relay"
Morley "Bad Horsie" Wah Wah
Would really apreciate any advise you could give, also would be good to be able to add another couple 9v pedals down the line
Thank you
-Dean
Re: Newbie could use some help/advice
Post by Rez » Fri Jun 29, 2018 12:47 pm
You could use Pedal Power 2 Plus.
To power these:
each uses: any 9VDC output with one of the all black (standard polarity) cables supplied.
To power the Digitech "The Drop" pedal use output 5 or 6, DIP switch set to NORMAL (9V), with one of the all black (standard polarity) cables supplied.
To power the Line 6 Guitar Wireless "G70 Relay" use a Current Doubler Adapter, part# PPAP in outputs 4 and 5 (or 6 and 7), DIP switches set to NORMAL (9V), with one of the all black (standard polarity) cables supplied.
And as these require AC power:
they can be powered from the AC courtesy outlet with their adapter/wall-wart (and an extension cord/power strip, etc).
DeanoGuitarist
Post by DeanoGuitarist » Sun Jul 01, 2018 9:39 am
Thanks so much Ben!! Just ordered one!
Post by Rez » Mon Jul 02, 2018 4:30 pm
Awesome and thank you!
DeanoGuitarist
Post by DeanoGuitarist » Tue Jul 03, 2018 3:30 am
Hi Ben! All arrived and about to set-up but I'm having a little trouble understanding the Current Doubler Adapter, part# PPAP bit for the Line 6 relay?
You see, the line 6 can be powered by either micro usb or standard way, but the cable you mentioned has two ends?
Is this correct cable? https://www.ebay.co.uk/itm/Voodoo-Labs- ... Sw2fpaoBTq
Post by Rez » Tue Jul 03, 2018 12:54 pm
That is the correct adapter (ie. current doubler). Its barrel ends connect to Pedal Power 2 Plus outputs 4 and 5 (or 6 and 7), DIP switches set to NORMAL (9V) and the green output (in-line jack) of the adapter connects with the G-70 with one of the all black (standard polarity) cables supplied.
