PP2P and Micropog
Racio
PP2P and Micropog
Post by Racio » Mon Jul 09, 2018 2:52 am
Hello everybody,
I'm a violinist and I started using a pedalboard recently therefore I'm still inexperienced. :roll:
Hoping that I'm using this forum in the right way (I'm not used), I'm thinking about buying the PP2P and I would like to be sure that everything will work fine.
My chain: Fulltone OCD
EHX Micropog
Catalinbread belle epoch
Tc Eletronic Ditto x2
Source Audio Nemesis Delay
Neunaber Immerse
Is the PP2P the right choice? I'm worried about the Micropog because of the recommendation of EHX to use its own power supply.
Again sorry for my inexperience and thanks to anyone will answer me!
Best regards
Re: PP2P and Micropog
Post by Rez » Tue Jul 10, 2018 12:52 pm
Yes, Pedal Power 2 plus is a sensible choice (or perhaps Pedal Power 4 x 4) and can nicely power all specified pedals.
To power the Micro POG use Pedal Power 2 Plus output 5 or 6, DIP switch set normal with one of the all black (standard polarity) cables supplied.
To power the Nemesis Delay use Pedal Power 2 Plus output 5 or 6, DIP switch set normal and one of the all black (standard polarity) cables supplied.
To power the remaining pedals, each: Use any 9VDC output (ie. DIP switch set to NORMAL), with one of the all black (standard polarity) cables supplied.
