brand new pedal power 2+ makes loud hum
magilla38
Post by magilla38 » Wed Jul 11, 2018 9:21 pm
i recently purchased a 2+ and i seem to be having a problem. i hooked up my board and turned on the amp and it immediately makes a loud hum. i started plugging things in one by one and checking. i can get 5 pedals hooked up but if i put a 6th in i get the hum.
setup works perfectly fine with my one spot daisy chain
tc polytune
boss OC-3
boss ODB-3
EHX big muff
EQD rainbow machine
EQD avalanche run( in postion 6 with normal switched up)
EHX 360 looper
tried with different amps and different cables etc and still have issues. i'm sure i'm missing something but i don't know what
Re: brand new pedal power 2+ makes loud hum
Post by Rez » Fri Jul 13, 2018 1:44 pm
My first guess would be the issue is power to your Avalanche Run. It should be setup:
To power your Avalanche Run with Pedal Power 2 Plus use a Current Doubler Adapter, part# PPAP in outputs 5 and 6, DIP switches set normal with one of the all black (standard polarity) cables supplied.
Any better?
magilla38
Post by magilla38 » Wed Aug 01, 2018 5:53 am
yeah that fixed it. didn’t realize the current draw on the avalanche run was that high. also had a bad cable that was causing most of the confusion. thanks.
Post by Rez » Wed Aug 01, 2018 12:29 pm
Awesome, I'm very glad that resolved it.
