Oceans 11 and Pedal Power +2
solid_snack88
Post by solid_snack88 » Thu Jul 12, 2018 10:37 am
i powered my oceans 11 using one outputs 1-4 at in my friends garage but the pedal led would just blink wildly and the pedal woudnt function. For the rest of the practice I just powered it using the power suppy the pedal came with but when I got home and tested out the voodoo lab again the pedal worked just fine. What could be causing this issue?
Re: Oceans 11 and Pedal Power +2
Post by Rez » Thu Jul 12, 2018 4:35 pm
It's because it requires 150mA (but the standard outputs are 100mA capacity).
To power the Oceans 11 use Pedal Power 2 Plus output 5 or 6, DIP switch set normal with one of the all black (standard polarity) cables supplied.
solid_snack88
Post by solid_snack88 » Thu Jul 12, 2018 4:43 pm
The standard outputs work just fine when I am at my studio but not in my friend's garage though.
Post by Rez » Fri Jul 13, 2018 1:28 pm
A likely explanation is:
As wall power can vary slightly from one venue to the next, a pedal powered from a source that is only very marginally sufficient, might work fine at one location but not at another.
