Pedal Power X4 vs Pedal Power X4 expander kit
trav16
Post by trav16 » Sun Jul 22, 2018 11:55 am
Can someone please explain to me the difference in:
https://www.amazon.com/Voodoo-Lab-Pedal ... B07BWBBZ1C
and
https://www.amazon.com/Voodoo-Lab-PPX4E ... B07BWPPCBY
can both of these be powered off of a pedal power 2? is there any immediate difference in these models?
Re: Pedal Power X4 vs Pedal Power X4 expander kit
Post by Rez » Mon Jul 23, 2018 3:05 pm
Purchased as an expander kit, there is no included power source. And as such, the X4 itself would be powered from a high current 12VDC output of some other Pedal Power supply (likely a Pedal Power 4x4 or Pedal Power MONDO) thus "expanding" the number of isolated outputs attainable from that supply.
Also... If used with Pedal Power 2, it likely makes sense to purchase it with the power adapter (ie. not as an expander kit). The power adapter could then be plugged into the Pedal Power 2 AC courtesy outlet to power X4 itself.
tokimasa
Post by tokimasa » Fri Aug 10, 2018 7:13 am
Rez wrote:Purchased as an expander kit, there is no included power source. And as such, the X4 itself would be powered from a high current 12VDC output of some other Pedal Power supply (likely a Pedal Power 4x4 or Pedal Power MONDO) thus "expanding" the number of isolated outputs attainable from that supply.
So here's another question...
What is the maximum mA the PP2+ can provide? and if you plug an x4 into the PP2+'s courtesy outlet, does that count against the maximum?
Post by JohnClark » Fri Aug 10, 2018 10:14 am
tokimasa wrote:So here's another question...
The Courtesy Outlet is completely independent from the DC Outputs. Connecting the X4 power adapter here will not affect the Pedal Power 2+ DC Outputs in any way.
On a Pedal Power 2+, the current limit for Outputs 1-4 and 7 & 8 are 100mA each. Outputs 5 and 6 are limited at 250mA each. All eight outputs are regulated and isolated.
tokimasa
Post by tokimasa » Fri Aug 10, 2018 10:27 am
That does help! Not that I am going to...but if I max out every one of the 8 outputs on my Pedal Power 2+, I will be ok??
The was something I read about the Pedal Power X4 having a total current draw of 1000 mA, so theoretically if you plugged in, say, 3 EQD Avalanche Runs (425 mA, I think), you'd exceed the capacity of the PP x4.
Post by JohnClark » Fri Aug 10, 2018 10:44 am
tokimasa wrote:That does help! Not that I am going to...but if I max out every one of the 8 outputs on my Pedal Power 2+, I will be ok??
You can run every Pedal Power output to its rated maximum, no problem.
The X4 is a different design and as such behaves a bit differently. It does not have higher and lower rated individual outputs like the Pedal Power 2+. Each X4 Output is capable of providing up to 500mA, but as you mention, you have to observe a total load of 1A (1000mA) across all the outputs. So no you couldn't really run three Avalance Run pedals at once on the X4 alone.
However in the case where the X4 is powered from the Pedal Power 2+ Courtesy Outlet you could power two Avalanche Run pedals on the X4 with room for two lower current pedals (your two favorite Fuzz pedals or a pair of Wah pedals perhaps ;) ) and power the third Avalanche Run from the Pedal Power 2+ using Outputs 5 and 6 combined with a Current Doubler Adapter (the one with the Green end) and have room for six more standard pedals.
More echo than yelling into the Grand Canyon!
tokimasa
Post by tokimasa » Fri Aug 10, 2018 11:03 am
haha, yes, that would be a whole lot of echoing.
Thank you for all of the info. Obviously, it's hypothetical, I can't imagine anyone really using 3 Avalanche Runs, but all great information. I did a lot of research on pedal power before getting the PP2+ and one of the main reasons I went with Voodoo Lab was the great support you guys provide.
Post by Rez » Mon Aug 13, 2018 4:02 pm
