Power cable replacement for Furman SPB-8C Powered Pedalboard
jkeeling
Post by jkeeling » Wed Oct 03, 2018 12:15 pm
I need to replace several power cables for my old (discontinued) Furman SPB-8C Powered Pedalboard. The manual describes the power cables as: 3.5mm phone plug (tip hot) to 2 mm x 5mm plug (sleeve hot)
Does Voodoo Lab offer a compatible power cable, and if so, what is the model number? I viewed the Voodoo Lab Power Cable Guide but did not find a cable that matched the above description.
thank you,
-john k.
Re: Power cable replacement for Furman SPB-8C Powered Pedalboard
Post by JohnClark » Wed Oct 03, 2018 2:58 pm
Our Mini Plug Cable should work for this. The 3.5mm Mini Plug would connect to your power supply and the 2.1mmx5.5mm is the standard size used by almost all guitar pedals these days, and it would maintain the correct Center Negative polarity that is also common to most guitar pedals.
