Welcome to the forum!
I'd probably go with the Pedal Power 2+ if this is everything, or Mondo if you were looking to expand.
The Polytune, TLC Compressor, Octamizer, and Bass Micro Synth can each be powered from any 9V Output.
The MXR EQ, if it is the M-108 Ten Band EQ, needs 18V and can be powered from any two 9V outputs using a
Voltage Doubler Adapter.
The Aftershock can be powered from any of the High Current 9V Outputs.
The Tonebone likely requires 15V and will need to use its supplied power adapter. This can be plugged into the Courtesy Outlet on the back of the Pedal Power 2+ or Mondo. Exactly which model Tonebone do you have?
