Using daisy chain as voltage doubler??
Ohardee
Post by Ohardee » Fri Apr 26, 2019 5:09 am
Hi folks, I’m in urgent need of a voltage doubler cable but don’t have one. I do have a daisy chain cable with a port at one end. Can I connect two of this to the PP2+ and one to the 18v pedal??
Not sure the wiring is more sophisticated than that...
Re: Using daisy chain as voltage doubler??
Post by JohnClark » Mon Apr 29, 2019 9:58 am
A Daisy Chain cable won't work as a Voltage Doubler... a Daisy Chain is wired in Parallel, while a Voltage Doubler would connect the Outputs in Series.
What is the one 18V pedal you are looking to power?
