ABY MIDI
Manhell
ABY MIDI
Post by Manhell » Thu May 28, 2009 7:17 pm
I think voodoo lab guys should do an upgrade to the amp selector and put midi in it, also could do an ABY box with midi. I know that the pedal switcher can do the A/B but it cannot do the Y right? and the GCX you need to have Y cables to split into two amps. get me right if I'm wrong, and expose your opinions about it.
James Santiago
Re: ABY MIDI
Post by James Santiago » Fri May 29, 2009 1:44 pm
Yes, the last loop of a Pedal Switcher can be used as an A/B switch. All of the GCX's loops can be used as A/B because they are all isolated with independent In-Send-Return-Out jacks.
You can see here that the Y-cable method is used to send the signal to 3 different preamps: http://www.voodoolab.com/gcxdiagrams/04 ... werAmp.pdf
Most likely, Amp Selector will stay as is. But, that's not to say that we don't see a need for a MIDI controlled version. It's just not on the schedule right now since a GCX can mostly perform those same functions. (Although, Amp Selector does have transformer isolated outs which helps to eliminate ground hum across all your amps.)
Thanks for your suggestions and keep them coming.
James Santiago
Vice President - Voodoo Lab
John01W
Re: ABY MIDI
Post by John01W » Fri May 29, 2009 8:46 pm
Not the thread creator, but the problem arises with ground loops because of no isolation. It would be easier and probably cheaper to just make it relay controlled so a gcx or control switcher could do it. Why have midi when you don't need it.
Josh Fiden
Site Admin
Re: ABY MIDI
Post by Josh Fiden » Fri May 29, 2009 11:38 pm
John01W wrote:Not the thread creator, but the problem arises with ground loops because of no isolation. It would be easier and probably cheaper to just make it relay controlled so a gcx or control switcher could do it. Why have midi when you don't need it.
Easier than that, you can simply add external isolation transformers to a GCX based rig. If possible, you're better off solving your ground issues, but when that isn't practical, a transformer is a simple solution.
Thanks for posting!
Josh Fiden
Founder / CEO
John01W
Re: ABY MIDI
Post by John01W » Fri May 29, 2009 11:52 pm
Thank you. Glad you guys put a forum up, I like the layout and extra stuff on here.
Thanks again for commenting Josh.
I know there's the rig builders who can make iso boxes(lasd, racksystems).
Another solution is the lehle p-split but using only the iso'd out on one loop and the other normal.
Trueman
Re: ABY MIDI
Post by Trueman » Sat May 30, 2009 9:02 pm
The Axess BS-2 also has an Isolated Output.
Connoisseur of good tone.
http://www.guitarpedals.co.nz
mibu
Re: ABY MIDI
Post by mibu » Sat May 30, 2009 10:37 pm
the lehle p-split II is even better! I have done lots of tests with the lehle iso transformers and they are of outstanding quality. if there's no other way to solve your problem, use those.
James Santiago
Re: ABY MIDI
Post by James Santiago » Sun May 31, 2009 1:46 pm
Mibu,
Great to have you on the forum!
James
James Santiago
mibu
Re: ABY MIDI
Post by mibu » Sun May 31, 2009 10:01 pm
hi james! yeah, it's good to have this forum. all the best wishes from good ole romania!
John01W
Re: ABY MIDI
Post by John01W » Mon Jun 01, 2009 10:14 pm
mibu wrote:the lehle p-split II is even better! I have done lots of tests with the lehle iso transformers and they are of outstanding quality. if there's no other way to solve your problem, use those.
Is the p-split II better? Do find that the transformer outs of the lehle splitters/switchers are pretty transparent?.
I've read a lot of good things about his transformer, even when compared to Jensen.
Thanks Mibu.
