volume and wah??
jollesen
volume and wah??
Post by jollesen » Fri Jul 17, 2009 3:37 pm
hi where do you place vol and wah pedals in the pedal switcher??
Re: volume and wah??
Post by JohnClark » Mon Jul 20, 2009 12:32 pm
Personally, I like to keep wahs out of switching systems. You can route it to whatever loop you like, but I always go with the thought that my foot has to be on the wah to use it anyway so I try to avoid having the bypass switch be elsewhere on the board. A traditional wah is quite simple to have converted to true bypass if it isn't already. A volume pedal can be routed before or after the Pedal Switcher or routed to the Insert between loops 3 and 4 with an insert point cable.
