It is currently Wed Jan 17, 2018 10:29 pm
 Post subject: Power Options for Ground Control Pro...
PostPosted: Fri Jul 31, 2015 7:51 am
Hello to all!
I have a GCP on a board that has a Pedal Power 2 Plus. I have two GCX's and one powers my GCP as of now with a 5 pin midi cable. I need to replace the wire and the one I have is 5 pins but only 3 conductor. I also have a 4x4 and ISO5 in my rack that powers different pedals and can't swap it to the front. I only use three outputs on the pedal power 2 on the board. I was wondering, can I use the current double adapter on output 5 & 6 (high current mode) with a 2.1 to 2.5 (red tip) to power my GCP??
Sorry if this has been answered before but I did not find this exact question regarding PPP2.
Many thanks!
Shawn
 Post subject: Re: Power Options for Ground Control Pro...
PostPosted: Fri Jul 31, 2015 10:36 am
No problem! Just make sure to leave to DIP switches for 5 and 6 set to Normal. You will also need to make sure to power up the GCX units before powering up the Ground Control Pro.
...or get a new MIDI cable with all 5 pins wired ;)
PostPosted: Fri Jul 31, 2015 11:05 am
Do I absolutely need to use the Current Doubler Adapter cable? Or just the 2.1mm to 2.5mm in the 5 0r 6 output would work?
Thanks John!!
Shawn
PostPosted: Fri Jul 31, 2015 11:31 am
You need the Current Doubler connected to both outputs. 250mA is definitely not enough current to reliably power a Ground Control Pro.
PostPosted: Fri Jul 31, 2015 1:25 pm
Got it!
Shawn
