Pedal Power 2 output issue
EGrossm
Post by EGrossm » Fri Aug 14, 2015 12:44 pm
Hey, my Pedal Power 2 seems to have power because the LED lights in each of the individual pedals on the board light up, but the rig produces very little volume. I've tested each cable, and my larger board (powered by two Pedal Power 2s) works perfectly, so I know it's not the amps or the guitar. Is it possible for the PP2 to produce enough power to light the LEDs but not enough to adequately power the rig?
Re: Pedal Power 2 output issue
Post by JohnClark » Fri Aug 14, 2015 1:08 pm
I guess one quick way to eliminate (or confirm :shock: ) the Pedal Power as the culprit would be to swap it with one of the other Pedal Power units you have.
Have you checked that each pedal operates individually as intended when connecting just the guitar directly to the pedal and the pedal directly to the amp?
What are the pedals you are powering?
