tremolo speed mod to have a better spread
fabsbox
Post by fabsbox » Thu Mar 03, 2016 10:08 am
I have a 4 knob voodoo lab tremolo that sounds great, but I'm only using the speeds with the speed knob between halfway and 3/4 open.
I often have to change the speed slightly between songs and like it is now, the speed knob is very sensitive, making it hard to do subtle adjustments, especially on a dark stage.
Before I start experimenting, can someone here tell me how I can mod the speed knob so it has a better/ smoother spread? I don't mind losing the really slow settings.
A different value of pot, another pot taper, change a resistor on the board or something else I didn't think of?
Fabian
Re: tremolo speed mod to have a better spread
Post by JohnClark » Fri Mar 04, 2016 11:27 am
This can be done if you can find a Dual 100K Reverse Audio (Reverse Logarithmic) pot that will fit inside the chassis. We use 16mm pots but you may be able to squeeze something else in there.
