Powerboard/Power Supply Help!!
stevezen
Post by stevezen » Sat Mar 19, 2016 11:09 am
Hi, I'm looking for a power supply that will accomodate a number of electronic pieces of gear to cut down on the mess of power cables I have. In my rig I'm running a Roland SPD-SX, Korg KP3+ Kaoss Pad, Roland 404Sx, Korg Wavedrum, a Xenyx 502 mixer, a TC Electronic Ditto X4 looper and an ART Power Mix III. I realize this is quite a large number of gear to run into a powerboard but it would make life and performance incredibly easier. Do you have any suggestions on what might work for at least some of the gear. Any help you can give me would be tremendously helpful. Thank you!!
Re: Powerboard/Power Supply Help!!
Post by JohnClark » Tue Mar 29, 2016 11:47 am
Of that list I think only the Art mixer and the Ditto X4 are appropriate for use with our power supplies.
Everything else has much larger current demands than typical guitar effects products. With current doubler cables you could probably get away with powering one or two of these but the whole setup becomes quite impractical to use this way I would think.
