It is currently Sat Mar 25, 2017 12:53 pm
 Post subject: How can I connect these pedals to the Voodoo Lab Mondo
PostPosted: Sun Jan 29, 2017 1:29 pm
Hi. I could use a little help. Is it possible to connect all the following pedals to the Voodoo Lab Mondo? If so, how? I researched the pedals & made the following list to help organize the problem - after pedal name it lists; the Power requirement, the current draw (mA), and the Plug/jack polarity . I'm still a bit confused about AC power connection requirements on the Tube Screamer, the Boss PH-3 Phase Shifter, Big Muff w/tone wicker, Deluxe Memory Man & Electric Mistress. Any help would be greatly appreciated !!
PEDAL / POWER - AC or DC / Current Draw (mA) / Plug or Jack Polarity
01) Polytune 2 (TC Elec.) / 9V DC / 100 /Cntr Neg
02) EP Booster (Xotic) / 9V DC / 5 /Cntr Neg
03) TS9 Tube Screamer(Ibanez) / 9V Dc / 7.5 / ?
04) Big Muff w/ Tone Wicker / AC ? / 50 /Cntr Neg
05) HOF Reverb (TC Elec) / 9V DC / 100 /Cntr Neg
06) Gen-TOCT Octave / 9V DC / ? /Cntr Neg
07) Deluxe Memory Man / 24V AC / 100 /Cntr Pos
08) ND-1 Nova Delay(TC Elec.) / 12V DC / 300 / ?
09) Electric Mistress (stereo) / 9.6V? DC / 200 /Cntr Neg
10) Deja Vibe CS-MDV-1(fulltone)/ 18V DC / 80 /Cntr Neg
11) PH-3 Phase Shifter(boss) / 9V AC / 50 /Cntr Neg
12) SP Compressor(Xotic) / 9V DC / 5 /Cntr Neg
13) Vox V487 Wah / 9V DC batt. / ? /Cntr Neg
 Post subject: Re: How can I connect these pedals to the Voodoo Lab Mondo
PostPosted: Mon Jan 30, 2017 12:03 pm
First is the good news, all of these pedals are actually DC and Mondo can power each pedal in one way or another. Where you run into some decision making is that you have more pedals than available outputs so you may need an Output Splitter Adapter or two...
The PolyTune2, EP Booster, SP Compressor, TS-9, Big Muff, HOF, PH-3, Vox Wah, and the Gen-Toct can each be powered from any output to the Right with the corresponding DIP switches set to Normal or any 9V Output to the Left. (You can use the PolyTune's power Output jack to gang to any one of the above pedals)
The Nova Delay can be powered from either High Current 12V Output to the Left. (you can still use the adjacent 9V Output to power any of the pedals above)
The Stereo Electric Mistress can be powered from output 5 or 6 to the Right with the corresponding DIP Switch set to Normal or from any 9V output to the Left.
The CS-MDV-1 Deja Vibe can be powered from any two outputs to the Right with the corresponding DIP switches set to Normal or any two 9V Outputs to the Left.
The Deluxe Memory Man (24V) can be powered from any two of outputs 1-4 to the Right with the corresponding DIP switches set to Normal.
Voodoo Lab ®
Magician/Tech
PostPosted: Mon Jan 30, 2017 4:33 pm
JOHN - Thank you so much for your help!
But, I'm a bit confused,
Question: - I noticed the default setting on the DIP switches for outputs #1-8 is on 9V (normal).
Since the Deluxe Memory Man is 24V, and I'm using outputs 1 & 2, shouldn't the corresponding switches be set to 12V (away from normal)?
