Digitech Trio Plus
Rich74
Digitech Trio Plus
Post by Rich74 » Tue Apr 04, 2017 1:27 am
Hi.
Can anyone help with if a Digitech Trio Plus can be powered by a Pedal Power 2?
I've noticed some suggestions of the PPAP adapter to give a current draw of 500ma, but in the Trio Plus manual it says the current draw requires 800ma.
Has anyone tried using the PPAP adapter with a Trio Plus?
Thanks.
Re: Digitech Trio Plus
Post by JohnClark » Tue Apr 04, 2017 9:29 am
The Trio+ is known to draw less than 500mA. It can be reliably powered using a Current Doubler Adapter (the one with the Green end) connected to outputs 5 and 6 on a Pedal power 2+ with the corresponding DIP switches set to Normal.
