It is currently Mon Jul 16, 2018 7:37 am
 Post subject: PX-8 Plus with Commander
PostPosted: Fri May 12, 2017 11:41 pm
Loving the PX-8 Plus! Just one question. Can I a Commander with it? I've tried it in Instant Access Mode with no luck so far.
 Post subject: Re: PX-8 Plus with Commander
PostPosted: Mon May 15, 2017 10:46 am
Right on!
Yes, the Commander will control PX-8 Plus, but it is a little different than previous switchers. PX-8 Plus will need to be set to have Program Changes enabled and to listen for them on MIDI Channel 1 in order to work with the Commander.
This is done as follows:
Enable Program Change
1. Hold button 1 while powering up the PX-8 Plus (All LEDs will flash).
2. Release button 1.
In this program mode LEDs 1 and 2 indicate Program Change and Control Change Enable.
3. Set LED #1 to On.
4. Power down the PX-8 Plus.
Set MIDI Channel 1
1. Hold button 2 while powering up the PX-8 Plus (All LEDs will flash).
2. Release button 2.
In this program mode LEDs 1 - 4 indicate the MIDI Channel.
3. Set LEDs 1 - 4 to Off.
If you will be in the all Instant Access mode, saving presets will be done as follows:
1. Press the desired Commander preset.
2. Press the combination of PX-8 Plus loop you want on for this preset.
3. Press PX-8 Plus buttons 1 and 6 at the same time to save the preset. (All LEDs will alternate flashing to confirm the save.)
PostPosted: Tue Aug 22, 2017 4:41 pm
I see the Commander has the " store " button.
Is it possible to save the preset pressing the " store " button instead of PX-8 PLUS buttons 1 & 6 ?
PostPosted: Thu Aug 24, 2017 11:35 am
The PX-8 Plus doesn't respond to the Store button on the Commander the way the older Pedal Switchers, and original PX-8 did. The PX-8 Plus will only respond to the Program Change each Commander Preset button sends. Storing the preset needs to be done on the PX-8 Plus itself.
