Slash 18v question
pumakick25
Slash 18v question
Post by pumakick25 » Wed Aug 30, 2017 9:21 pm
Have a slash wah 18v 30 mA ...can I use the pedal power 2 plus outputs 5 and 6 for the 18v voltage converter or is it too many mA? Cant use the other outputs due to other pedals
Re: Slash 18v question
Post by JohnClark » Thu Aug 31, 2017 9:37 am
You can power the SW95 from any two outputs on a Pedal Power 2+ with the corresponding DIP Switches set to Normal using our Voltage Doubler Adapter, including outputs 5 and 6.
The current rating of an output is stating the maximum current that output is capable of providing but any pedal will draw only the amount of current it needs to operate. It is perfectly safe to power a low current draw pedal from a higher current output.
pumakick25
Post by pumakick25 » Thu Aug 31, 2017 9:22 pm
