Px 8 plus fx loop
Shaico
Px 8 plus fx loop
Post by Shaico » Sun Oct 28, 2018 8:19 am
Hi
Can someone Please tell me if i can ran my delay/ reverb in my amp fx loop or do wet/dry setup with the insert on the px 8 plus and how to do this setup
Appreciate the help🤘
Re: Px 8 plus fx loop
Post by JohnClark » Mon Oct 29, 2018 9:12 am
No problemo!
1. Connect your guitar to PX-8 Plus Input.
2. Connect the PX-8 Plus Insert Send to the Instrument Input of your amp.
Pedals in Loops 1-6 will be routed to the front of the amp.
3. Connect the FX Send from your amp to the Insert Return on the PX-8 Plus.
4. Connect the PX-8 Plus Output to the FX Return on your amp.
Pedals in Loops 7 & 8 will be routed to the FX Loop of your amp.
What amps do you use for your Wet/Dry setup?
Shaico
Post by Shaico » Mon Oct 29, 2018 2:36 pm
Thanks for the replay..
Your explanation solved everything !!!
I have 2 blackstar ht20 for wet/dry setup using only 1 pre amp
all my dry fx from px8 plus insert send to amp input
Insert return to amp fx send
second amp is wet connected in return fx loop from the px 8 plus output
Can i run stereo setup with the px 8 plus ?
Post by JohnClark » Tue Oct 30, 2018 10:48 am
Glad to help!
The loops on PX-8 Plus are all Mono.
What Delay and Reverb are you using? If they are MIDI Controllable, you may be able to control them with PX-8 Presets rather than using PX-8 Plus Loops and then connect them in stereo directly to your two amps.
