How to use Ground Control Pro with three HEX.
seguroloureiro
Post by seguroloureiro » Tue Apr 23, 2019 12:29 am
Good morning, I would like, if possible, ir someone code tale me a question about the use of my ground control pro and three hex simultaneously. What happens is that I would like to have access to each one of the loops ou me hex , I can connect the loops of my first hex through gcp, but the following ones, even after they are activated, can only be accessed when I am programming the hex. pressets. Thank you
Ricardo Loureiro
Re: How to use Ground Control Pro with three HEX.
Post by JohnClark » Tue Apr 23, 2019 10:35 am
The Ground Control Pro has Eight Instant access buttons. These can be programmed to control any loop in your system, but you are limited to a total of Eight Instant Access switches.
Ground Control Pro Presets will set all all the loops at once for repeatable loop combinations without having to step on a bunch of buttons.
