Skrydstrup SC1 & GCX
olliaimola
Post by olliaimola » Sun Jun 02, 2019 10:42 am
Hi!
I’m thinking of getting myself second GCX. I’ve read a post from here that says that if I want to use different controller than GCP with several GCXs there are two options: send sysex message or insert custom chip to second and third and fourth GCX.
Skrydstrup SC1 controller can’t send sysex messages so how can I get that chip that would make the second GCX to respond to different CC than the first? And is it easy to install?
Best regards,
Olli Aimola
Re: Skrydstrup SC1 & GCX
Post by JohnClark » Mon Jun 03, 2019 11:58 am
To get the replacement chip you would want to give us a call or write to info@voodoolab.com. The chip is in a socket so there is no soldering involved.
A GCX #2 chip will force the unit to respond to Control Change messages 88-95 on MIDI Channel 16.
