Ground control pro midi out pinout
pedro#9
Post by pedro#9 » Sun Jul 07, 2019 5:22 am
Hello all,
Can someone share the EXACT pinout of the output of the midi connector of the ground control pro ? I m looking at powering the gcp from my own power supply and would like to have only one cable to carry power and midi messages.
If someone is interested I might share my Pcb in order to “inject” power in the midi cable of the gcp.
Pierre
Marlboro05
Re: Ground control pro midi out pinout
Post by Marlboro05 » Sun Jul 07, 2019 8:10 pm
Hi Pierre,
This may be useful to you
viewtopic.php?f=9&t=9015&p=28657#p28657
Pins 1 and 3 are for power, all the rest straight through.
And some other stuff.
Post by JohnClark » Mon Jul 08, 2019 11:00 am
This is the Ground Control Pro MIDI Out jack...
GCP MIDI Out.jpg (15.69 KiB) Viewed 1616 times
As mentioned above, its a standard MIDI Out with the addition that Pins 1 & 3 OR Pins 6 & 7 accept Phantom Power. The Ground Control Pro will accept 9V AC or DC and should get at least 400mA.
pedro#9
Post by pedro#9 » Tue Jul 09, 2019 2:26 pm
Thanks a lot guys !
Cheers from France
