Px-8 Plus Pedal Switcher and pedal order
eharding
Post by eharding » Thu Jul 11, 2019 2:41 pm
I understand you can program the board to activate specific pedal combinations at the push of a button.
Can you program the order in which one pedal's signal enters another pedal during those combinations? Or is the signal dictated in how you run your cable from pedal to pedal?
Re: Px-8 Plus Pedal Switcher and pedal order
Post by JohnClark » Mon Jul 15, 2019 1:37 pm
The pedal order is fixed. Basically, Loop 1 is first in the chain and Loop 8 is last. For instance, you cannot swap the order so that loop 2 is before Loop 1.
eharding
Post by eharding » Mon Jul 22, 2019 6:13 pm
Thank you John!
