Pedal Switcher controlled by midi
ewierzbicki
Post by ewierzbicki » Sun Sep 22, 2019 2:15 am
Hello!
I'm 4-loop Pedal Switcher and Commander user and I've got some big midi controllers sending ProgramChange and ControlChange commands. I would be happy to control my Pedal Switcher by midi commands.
I've found some information, that Pedal Switcher responds to PC commands, but no details. I've sent some PC 1-10 on channels 1-16 with no effects.
I've also found, that Commander responds to PC 1-10
on channel 1. Checked and it doesn't work... Checked all the 1-16 Channels
Please help.
Od maybe there's a way to modify PedalSwitcher's ROMs to make every loop responding to CC command? It would be terrific!
Re: Pedal Switcher controlled by midi
Post by JohnClark » Mon Sep 23, 2019 10:30 am
Pedal Switcher (the original 4-Loop version) does not accept Program Changes. However it can be controlled using Control Changes 80-83 on MIDI Channel 16 if it is first sent the following SysEx string:
F0 00 00 07 01 08 10 F7
Alternatively, we do have a modified firmware that will force this Control Change Mode if your MIDI Controller cannot send System Exclusive messages.
The Commander was originally intended to accept Program Changes, but if i remember correctly, this never actually made it into the firmware code :?
What MIDI Controller will you be using?
braveheart
Post by braveheart » Tue Oct 01, 2019 10:08 am
where can I get the firmware to enable program changes?
thanks Olly
Post by JohnClark » Tue Oct 01, 2019 11:14 am
thanks Olly
For what device? As I mentioned above the Pedal Switcher does NOT respond to Program Changes, but there is an alternate firmware to force it to respond to Control Change messages if you cannot send the SysEx message that accomplishes the same thing.
The Commander never really got an update to enable Program Changes... or at least I cannot find one :oops:
Part of discontinuing these designs has to do with the processor they used being discontinued from its manufacturer. There is no new code being written for these legacy products.
braveheart
Post by braveheart » Tue Oct 01, 2019 12:17 pm
thanks,John
I guess I need a proper Midi controller... ;)
Are the Roland FC-300, the Ground Control (dicontinued),Ground Control Pro able to control the pedal switcher `?
Olly
Post by JohnClark » Wed Oct 02, 2019 10:29 am
thanks,John
Olly
Both the original Ground Control and the Ground Control Pro can absolutely control the Pedal Switcher without modification. Our controllers treat the Pedal Switcher as if it were a GCX.
The FC-300 does not look like it can be programmed to send the necessary SysEx message, but it does look to be able to send Control Change messages. So with an FC-300, the Pedal Switcher would need the modified firmware that forces it into "GCX Mode".
