It is currently Fri Jul 20, 2018 1:07 pm
 Post subject: Rig Set Up
PostPosted: Sun May 31, 2009 2:23 pm
Hey, what's up? This is my first post here and I have added a couple new pre amps to my rig and need a little help My set up has a Mesa Mark IV Rack unit and a Mesa Satellite Rack unit, (2) GCX switchers, G Force FX unit, Mesa Recto Pre Amp, and a ADA MP! Pre amp. So what I would like to do is switch between the 3 pre amps through the Mark's power sections and G Force , running stereo. I did see the one example on the web site using "Y" cables. Would I need to use a "Y" cable with 2 GCX Switchers? Any help would be much appreciated!!!
Thanks..
CURRENT GEAR SET UP
MESA MARK V HEAD
MESA MARK IV RM
MESA MARK SATELLITE RM
MESA SWITCHER
(2) GCX SWITCHERS
G FORCE
DMC GPC
FURMAN POWER CONDITIONER
MESA 12SP SUS 4
(2) MESA 4X12 RECTO CABINETS
(2) MESA 2X12 RECTO CABINETS
MY BALLS
 Post subject: Re: Rig Set Up
PostPosted: Sun May 31, 2009 3:21 pm
Site Admin
This is an example of switching between 3 preamps from the GCX page:
Multiple Preamps
You need to split the signal into the inputs of all 3 preamps. As long is it is buffered, you can do it with Y cables. If you use the GCX Guitar In, then you have Guitar Out and Feed Thru to get 2 and use a Y-cable for the 3rd. Then use 2 loops as A/B switches to select between the 3 preamp outputs as shown.
If you print the blank GCX worksheet, draw it up and post, someone can check what you're doing.
Josh Fiden
Founder / CEO
PostPosted: Tue Jun 02, 2009 3:11 pm
How do I post my layout?
CURRENT GEAR SET UP
MESA MARK V HEAD
MESA MARK IV RM
MESA SWITCHER
(2) GCX SWITCHERS
G FORCE
DMC GPC
MESA 12SP SUS 4
MY BALLS
PostPosted: Wed Jun 03, 2009 1:10 am
When you reply there is a window underneath to add a attachment. Save the PDF as .jpg and upload.
Connoisseur of good tone.
http://www.guitarpedals.co.nz
Users browsing this forum: Bing [Bot] and 9 guests
