Ground Control Pro and a Slave?
JLBAXE
Post by JLBAXE » Fri Jun 19, 2009 7:07 am
Quick question. I have a Ground control pro and 2 gcx's. The first GCX has 2 Egnater M4's and a mod50 in the first 3 loops, loop 6 7 and 8 used for bypassing 3 effects. the 2nd GCX has 4 rack effects (TC2290 1210 spacial, BK tube driver, Dual Rat R2DU,Digitech 33B IPS, Digitech RPM-1) and 3 pedals GE7,BK tube driver Maxon OD808. I was wandering if I can run a second GCP as a slave (instant access) so I can punch in/out effects on the fly but still have the master control the entire rig. If I decided to add or remove an effect for whatever reason I simply could.
sasquatch
Re: Ground Control Pro and a Slave?
Post by sasquatch » Fri Jun 19, 2009 9:17 pm
i have asked the same question about the preset changes with two ground controls and two gcx's. no reply. i dont care if i can only use one gc to change the prests, but i need more instant access switches too, and for them to be included in the preset changes. sorry i am no help. if it cant do this axess electronics do a really good controller that is expandable for more instant access, but they are currently not dealing for a few months. VDL also wont comment as to if they are planning any expansion for the ground control. i wish they would because i love their products and, beside this issue, have never had any problems, and i own just about everything they sell.
JLBAXE
Post by JLBAXE » Sat Jun 20, 2009 7:58 am
They sent me an email saying they were checking on it and asked what ver number my gcp was. So maybe they are working on something or trying to see if it will work.
JLBAXE
Post by JLBAXE » Sat Jun 20, 2009 8:04 am
Under settings....Midi...I have Link Master or Link Slave...????? This makes me think I can hook up another GCP to Midi in and set up Slave as instant access buttons and leave Master as Program buttons. I know Slave is for a different spot on the stage or for the tech behind the stage but do they have to be hooked up and run the same?
JLBAXE
Post by JLBAXE » Thu Jun 25, 2009 6:23 am
Well??????????????????????????????????????
John01W
Post by John01W » Fri Jun 26, 2009 8:01 am
I was wondering about this too.....from what I remember you end up having 4 worthless preset buttons on the slave gcp.
Man, demand is high for the expander now. Seems like it's every other thread since the forum is up...lots of folks over at hri too for some time now. I need one too(gcp expander)....been waiting a while.
Post by JohnClark » Fri Jun 26, 2009 10:13 am
You can connect two v1.10 or higher Ground Control Pro units in order to get more Instant Access switches. If you enable the Link Mode then the second unit will show preset changes made on the first unit.
JLBAXE
Post by JLBAXE » Fri Jun 26, 2009 6:48 pm
Can you buy a chip to up grade to V1.10 ?
JLBAXE
Post by JLBAXE » Fri Jun 26, 2009 6:53 pm
John01W wrote:I was wondering about this too.....from what I remember you end up having 4 worthless preset buttons on the slave gcp.
So you have 1-8 for instant access buttons? the bottom 4 useless?
I could really use 16 instant access buttons. need something like a Bradshaw switcher.
mikeromancer
Post by mikeromancer » Mon Jun 29, 2009 1:43 pm
I still have my Ground Link (2 actually) and was wondering if I could use it with my GCP to gain 8 more instant access switches. Right now, it just duplicates the GCP access settings.
