midi, power options for two GCX and one GCP
hernando04
Post by hernando04 » Mon Apr 04, 2011 12:55 pm
Do I need both wall wart plugs to use 2 GCX switchers or can one wall wart plug power both with a midi cable in between the 2 units? If one is good enough, which one do I plug in, the one that is connected to the Ground Control or the other one?
Re: midi, power options for two GCX and one GCP
Post by JohnClark » Mon Apr 04, 2011 2:44 pm
Each GCX will require its own power supply.
dawesy1986
Post by dawesy1986 » Thu Aug 25, 2011 4:33 am
Bear in mind one Pedal Power AC will power each unit PLUS the GCP using only two of the four outputs! :D best power supplies!
