Voodoo Lab
http://voodoolab.com/forum/
Tap Tempo Pedal Build for the GCP
http://voodoolab.com/forum/viewtopic.php?f=9&t=2914
Page 3 of 3
Author:  JohnClark [ Thu Dec 11, 2014 12:53 pm ]
Post subject:  Re: Tap Tempo Pedal Build for the GCP
Currently, the Ground Control Pro will only accept a Latching switch.
Author:  The Blue Letter [ Mon May 11, 2015 7:00 am ]
Has anyone successfully built a tap tempo for the GCP that has an LED in it to flash at the tempo rate?
Author:  Meanoldfireman [ Fri Oct 02, 2015 3:32 pm ]
Curious if this still requires a latching switch or if a Firmware revision for the GCP covers it.
Author:  JohnClark [ Fri Oct 02, 2015 6:15 pm ]
Ground Control Pro will not support a momentary switch connected to the Expression pedal port.
Author:  Meanoldfireman [ Sat Oct 03, 2015 5:48 am ]
Thanks. I'll hunt around the shop for a latching switch. I just happened to have a momentary action one on my bench.
Author:  bettsaj [ Fri May 19, 2017 12:25 am ]
Could this foot switch be used to control tap tempo on a G-Force via the control input on the back of the G-Force??
Author:  JohnClark [ Fri May 19, 2017 10:29 am ]
I doubt it... the G-Force External Control jack is wired for a "TS" (Mono) connection. This switch is wired for a "TRS" (Stereo) connection.
Author:  bettsaj [ Sat May 20, 2017 12:54 am ]
So, in that case it could be adapted.... Any idea how it could be wired to work with a ts Jack.... Both my expression pedal inputs on my gcp are being used for pedals, and I'd like a tap tempo button without using up a button on the gcp
Author:  JohnClark [ Mon May 22, 2017 10:09 am ]
I'd think any off the shelf type switch would work with the G-Force, no need to fabricate one. However, the wiring for a TS jack would be to simply have the switch open or close the connection between the Tip and Sleeve.
Author:  bettsaj [ Fri Jun 09, 2017 12:22 am ]
Of course..... I've looked at the cost and i have some bits lying around... I just need to buy a small enclosure and a momentary normally open switch. Cheaper and probably quicker to make one for what it is.
Page 3 of 3 All times are UTC - 8 hours [ DST ]
http://www.phpbb.com/
